Easiest way to trim/delete clip without affecting other clips in timeline?
Morten Slemdal
on Jan 3, 2014 at 2:46:18 am
Easiest way to trim/delete clip without affecting other clips in timeline?I can just use P, but that only works in primary track? When I use this on other tracks, it just doesnt work?
Jeremy Garchow
Re: Easiest way to trim/delete clip without affecting other clips in timeline?
on Jan 3, 2014 at 3:25:32 am
The position tool works in secondary story lines just like it does in the primary.
Morten Slemdal
on Jan 3, 2014 at 8:45:14 am
Strange - when I use P and delete the clip in secondary storyline, it does'nt affect my primary, but it sure affect my secondary.
Jeremy Garchow
on Jan 3, 2014 at 2:28:13 pm
[Morten Slemdal] "Strange - when I use P and delete the clip in secondary storyline, it does'nt affect my primary, but it sure affect my secondary."
Isn't that what you want?
Morten Slemdal
on Jan 3, 2014 at 3:13:28 pm
He, he. Yes, but just by deleting the clip, leaving the space open, and show the primary. Now all the medium on the right side of the clip are pulled back to fill the empy room. It messes everything up.
Jeremy Garchow
on Jan 3, 2014 at 4:48:53 pm
Select the clip you want to delete and then shut shift delete.
This leaves a gap.
Is this what you need?
