Backups
James Ewart
Backups
on Dec 30, 2013 at 1:05:30 pm
A little confused. Trying to figure out what is where.
Ripple tell me my backups folder by default is in the project library bundle of the relevant hard drive. They say that by selecting a library and then selecting preferences we can determine where the backups of that library will be stored. This is not my experience (I don't think) and it seems that whatever I select for on library is the same backups location for all of them. This then presents a problem as if you you do wish to open a backup you get a list but it dos not refer in any where to the original library name...it's just a list with numbers
Mine appears to be in my movies folder of my internal drive but when I look at that I find four Libraries/bundles
See photo 1
None of which contain a backups folder but do bizarrely contain a folder of all the updated projects from the initial update that I though I had moved back into their relevant Events.
See photo 2
However if I go to open the project Library bundle on an external drive I find a plethora of backup folders for Events and projects
photo 3
Perhaps I should not have embarked on this journey but there are times when I may want to open a backup of a project (timeline) rather than an entire Library.
Has anybody got a handle on this and apologies if am not being clear. I think I may have changed the default back up location in preferences which may be causing the confusion. However the suggested location in the drop down window (Backups) does not reappear so how do I restore the default location for backups I wonder?
I've got myself into a right old muddle I must say.
Jeremy Garchow
Re: Backups
on Dec 30, 2013 at 2:46:38 pm
Is too many backups a bad thing. :)
Really, the only thing that hs been added is library backups, the other backups were in place in 10.0.3 or something.
Bret Williams
Re: Backups
on Dec 30, 2013 at 3:52:36 pm
I think I see the problem. You updated all your projects and events together into one singular library? In the movies folder on your internal, is the backups of your libraries. You only have one. Inside that library you have multiple projects. Within the event, in your second example, you see the backups of each project. There has always be the one backup of a project. The previous version. I've never quite been sure how to use that and figured I'd COW it if I ever needed to.
But the backup in your movies folder works exactly like autosaves in FCP 7. It's going to open a previous version of your library. And if you haven't figured out yet, libraries are generally treated like legacy "projects." And in this case they definitely are. To access these backups, which are simply numbered by a timestamp inside a folder with the name of the library, just like autosaves of legacy, you go to file>open library>from backup. You'll be given choices of dates and times of the backups for that library of when you want to restore.
Now, since you can't do a "save as" in FCP X like legacy, this could be a very dangerous thing. I'm not sure what happens when you choose one of these libraries. Does it replace the current library? In legacy, you could open it, check it out, copy something from it, or save it over the current project, etc. But since X is in charge of it's own saving, it could be disastrous.
Why apple got rid of saving I have no idea. And why they screwed it up in their other apps with "duplicates" and all that other crap I have no idea. FWIW, if anyone is sick of not having "save as" in other apple apps like pages, just hold down option and go to the file menu and there it is. Save as. But not in FCP X.
Here's my backups folder right now for example. One library for each project...
Bill Davis
Re: Backups
on Dec 30, 2013 at 4:10:14 pm
[Bret Williams] "Why apple got rid of saving I have no idea. And why they screwed it up in their other apps with "duplicates" and all that other crap I have no idea. FWIW, if anyone is sick of not having "save as" in other apple apps like pages, just hold down option and go to the file menu and there it is. Save as. But not in FCP X.
But they didtn't actually "get rid" of saving. They just made it a persistent auto-function."
They moved to a finder wide system where saving is a process of storing incrementall metadata updates just like the autosave works in X.
Essentially you don't need to "Save As" if there's a automatically generated archive of timed states of your work as it's progressed. SaveAs merely cut a paritcular document off from it's own history. And if you DO Want to cut the document off from it's history - what do you need? Oh, a DUPLICATE of where it is right now.
The new system exists because unlike when SaveAs was important - storage is cheap and computers are fast and text strings can be massive and still handled and passed around virtually instantly with all their history intact in a single file.
Save As is gone because it's largely an attifact of an era where computers were slow and less dependable and you always had to write a copy of everything to fixed media, just order to be "safe."
The only ones discomforted by it are guys like you and me who had lots and lots of years to get accustomed to expecting the old system.
ANd yes, I sometimes miss it too. But I'm getting over it - slowly.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Bret Williams
Re: Backups
on Dec 30, 2013 at 4:16:27 pm
Understood. And not usually a problem. In fact, I've never lost more than a single action when X has crashed. But now, with the library autosaves, it seems there is an issue. What if I do a restore? It seems it will replace the current? Yes, the current state would have an autosave too, but doesn't that start to become messy?
I know what I would do. I'd open the autosave library from the finder so that it opens alongside my current iteration and I could copy over a project or element that I needed to.
Jeremy Garchow
Re: Backups
on Dec 30, 2013 at 7:51:01 pm
[Bret Williams] " What if I do a restore? It seems it will replace the current? Yes, the current state would have an autosave too, but doesn't that start to become messy? "
You can Finder dupe libraries and open that dupe. People hated how FCPX "did everything for you" including backups. Well, now, you have more control and the mess is in your hands.
If you think of a Library as an FCP7 project file that can hold media, it's much easier.
There are, of course, different nuances and functionalities, but having automated backups or user created backups isn't all that bad in my opinion.
If you open a Backup with the "Open Library > from Backup" command, a copy opens next to the original that is dated the time the backup was made. It is the exact same thing as opening it form the Finder by double clicking, or opening the Library from within FCPX.
As far as keeping both of them, you probably wouldn't work on both of them at the same time, but you could certainly rename the backup the same as your current Library and keep working in case of disaster.
Bret Williams
Re: Backups
on Dec 30, 2013 at 8:43:21 pm
Have you tried it? It is bullet proof, but the instant you double click the backup library, it duplicates that backup library to the same folder as the library it is a backup of, AND instantly begins consolidating the media. So the media no longer links to the media in the original. It's essentially bullet proof, so I can now immediately delete the original (after the consolidate is complete) and rename the backup to the name of the original. Great. But geez, by double clicking that backup file, I lost 27gigs of HD space no questions asked or warnings given. I suppose it might have said something if I didn't have enough space.
Sometimes it's good to work through all these things and see what happens!
Jeremy Garchow
Re: Backups
on Dec 30, 2013 at 9:14:29 pm
[Bret Williams] "Have you tried it? "
I have.
[Bret Williams] "It is bullet proof, but the instant you double click the backup library, it duplicates that backup library to the same folder as the library it is a backup of, AND instantly begins consolidating the media. So the media no longer links to the media in the original. It's essentially bullet proof, so I can now immediately delete the original (after the consolidate is complete) and rename the backup to the name of the original. Great. But geez, by double clicking that backup file, I lost 27gigs of HD space no questions asked or warnings given. I suppose it might have said something if I didn't have enough space."
It really seems to be nearly the same thing as restoring the backup in FCPX. All my media is usually external.
The backup files are very small as they are stripped of ANY media.
But I find that if I double click a backup, it ends up the same size as the original minus any project renders and Proxy media. Linked media remains linked.
If you dupe the backup. move it, and open it, it loses the connection to the original, but stays smaller.
Mark Spencer
Re: Backups
on Dec 30, 2013 at 9:16:28 pm
1) Our training was incorrect, the backups are stored in the Movies folder as you discovered
2) Opening a backup doesn't affect the current library. It's completely separate.
3) Backups of libraries don't include media, even if the library is "managed" -e.g., media is store in the library. Rather, the backup contains sym links to the actual media location
4) They've worked just fine in our testing.
Mark
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Jeremy Garchow
Re: Backups
on Dec 30, 2013 at 9:22:08 pm
[Mark Spencer] "1) Our training was incorrect, the backups are stored in the Movies folder as you discovered"
That is the default location, but backups can be stored anywhere of your choosing in the prefs:
Mark Spencer
Re: Backups
on Dec 30, 2013 at 9:34:06 pm
Yes that is true - and best to put them on a drive that is being backed up regularly, or on a drive that does not contain your source libraries.
Mark Spencer
Bret Williams
Re: Backups
on Dec 30, 2013 at 9:21:07 pm
On this current project, I keep the camera originals external, but the AVCHD that had to be rewrapped isn't, since the project started as a 10.0.9 project. That's 27gigs. So, the interesting thing is that the backups are only 15megs. They obviously link directly to the media in the event of the original library. Something you can't do normally. But, upon double clicking or restoring that project, it places a copy of it right beside the original it's backing up, and immediately consolidates it so it to balloons to 27gigs just like the library it's backing up. The library I double clicked remains where it is at 15mb. It's very smart. But sure sucks up the drive space.
Jeremy Garchow
Re: Backups
on Dec 30, 2013 at 10:32:35 pm
[Bret Williams] "On this current project, I keep the camera originals external, but the AVCHD that had to be rewrapped isn't, since the project started as a 10.0.9 project. That's 27gigs. "
Of it is the original media, that is h264 and not ProRes optimized, you can consolidate it out.
Once out, everything that is linked will stay linked.
If it's managed or generated in the library, it will dupe.
Jeremy
Dave Jenkins
Re: Backups
on Dec 31, 2013 at 5:46:28 am
If I'm understanding what your saying... the back ups when opened don't take up more space. I just opened a back up, the original was 10gigs and back up says 10gigs but if you look at the HD space it doesn't go up by 10gigs. If you throw the back up in the trash and empty the trash the HD space doesn't change.
Dajen Productions, Santa Barbara, CA
MacPro 3.2GHz Quad Core - AJA Kona LHe+
FCS 3 OS X 10.7.4
FCP X, Logic Pro, Squeeze, Filemaker 10.8.3
Bret Williams
Re: Backups
on Dec 31, 2013 at 7:08:46 am
No, they will likely take up a lot more space when a backup is opened. Depending on your workflow. If you copy media to the event when importing then you'll be in for a world o' bloat. The backups themselves are nothing but data. They actually do what no library that you and I create can do, they LINK to the media in another library. They have to or they'd be huge if they were a copy of say a 10 gig library every 20 minutes. But the minute you open one, they copy themselves to the same directory as the library they're backing up, and rename themselves to the same name as the library they're backing up PLUS the timestamp. All good right? And then, now that it's a mortal library and not in the library backup anymore, it immediately has to live by mortal rules and so it has to consolidate all the media. But as Jeremy points out it's just the internally managed media. So any files that weren't externally linked originally will be consolidated.
In my case that was 27gigs of rewrapped AVCHD files. As he pointed out, I could have moved those files out of the event with the consolidate command once I was using 10.1, but hey, I didn't think of it because I'm just learning all this stuff on the fly like so many of us. But that's the way I learn. Can't memorize crap. But once I've done something I tend not to forget it. In the future I'll be externally managing every file FCP X allows.
James Ewart
Re: Backups
on Dec 31, 2013 at 8:39:10 am
Plus Mark Spencer kindly introduced me to the concept of "Relink from camera archive". Which is a very useful thing to have I reckon. But where is that command I cannot find it?
James Ewart
Re: Backups
on Dec 31, 2013 at 12:59:31 pm
Out of interest tried having a look inside some of those backup folders in the library with show package contents.
Wtf!
