Recovered a lot of hard drive space with 10.1
Claude Lyneis
on Dec 28, 2013 at 6:23:33 am
My 2 TB disk was close to full, mostly with FCPX projects and events. After converting to 10.1, I have a TB free. I had a lot of render files and other miscellaneous stuff from using FCPX in a less than precise way and apparently going to FCPX10.1 meant that those render files and other unneeded files were not carried over. In my case that is a good thing.
Also, a few original files turned up missing and I found them on a backup disk and 10.1 relinked them and it put the originals back where they should be.
Interesting.
Mark Spencer
Re: Recovered a lot of hard drive space with 10.1
on Dec 29, 2013 at 1:14:29 am
When you update, none of your render files are carried over.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
