Question regarding projects/events in 10 .1
Jack Niedenthal
on Dec 28, 2013 at 12:46:27 am
I used to use Event Manager in 10.0.9 because I have a lot of projects (2 feature films, commercials, infomercials, etc). Before I began to use Event Manager FCPX took forever to open.
My question is, now that Apple has set things up differently in 10.1 with regard to Projects/Events, is opening FCPX with everything loaded not an issue anymore in terms of how quickly it boots up?
Jack Niedenthal
Microwave Films of the Marshall Islands
http://www.microwavefilms.org
http://www.microwavefilms.org/Crickets.html
iMac i7 using Mavericks 10.9.x, HPX 170 using only one 64GB card
I live on an island in the middle of the Pacific, YOU are my only resource.
Bret Williams
Re: Question regarding projects/events in 10 .1
on Dec 28, 2013 at 1:16:08 am
It might be a little better, but the whole point of libraries is to address what event manager addressed. It takes a lot of resources to open all your edits on any app, so you likely want to group events and projects into libraries. Probably a library for each job.
Jeremy Garchow
on Dec 28, 2013 at 6:12:22 pm
And libraries do seem to load much faster than separate Events/Projects.
