Timeline Question
Jordan Mena
Timeline Question
on Dec 23, 2013 at 5:33:22 pm
I've noticed that when I use option+command+down on certain clips will either extend or shift a clip by a frame instead of just shifting the clip down to the primary storyline. Is this a bug or based on certain clip perimeters i'm not aware of?
Thanks, J
Jordan Mena | Editor | Colorist | Producer
Los Angeles, CA
jordanmena.com
Jordan Mena
Re: Timeline Question
on Dec 23, 2013 at 5:42:02 pm
BTW, 10.0.9 :)
Los Angeles, CA
jordanmena.com
Mark Morache
on Dec 23, 2013 at 7:52:18 pm
I haven't run into that. I'm wondering... are you mixing frame rates or anything? Maybe it's trying to find the next closest frame.
It's easy enough to adjust afterwards, it should work.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
Jordan Mena
on Dec 23, 2013 at 8:55:44 pm
Frame rate is all the same. The reason I'm asking is it ripples the timeline and for promo work a :30 is a :30. Easy enough to fix using the position tool. Just thought i'd ask.
Los Angeles, CA
jordanmena.com
