new Mac Pro: HDMI and 1080i
Krzysztof Lorent
on Dec 20, 2013 at 10:41:24 am
What is the HDMI signal output: 1080i or 1080p? In other words, need I to buy a Blackmagic Intensity Extreme to watch the material in interlace monitor LMD 2110W?
Craig Alan
Re: new Mac Pro: HDMI and 1080i
on Dec 23, 2013 at 6:37:13 am
Standard-speed HDMI cables are rated up to 1080i. They might do more than this, but they're just rated for 1080i. High-speed HDMI cables are rated above 1080p. The cable does not determine the
[Krzysztof Lorent] "signal output".
Mac Pro, macbook pro, Imacs (i7); Camcorders: Panasonic AG-HPX170/AG-HPX250P, Canon HV30/40, Sony Z7U, VX2000, PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Krzysztof Lorent
on Dec 27, 2013 at 10:56:06 am
Sorry. I mean what is on the HDMI output New Mac 1080p or 1080i?
Craig Alan
on Dec 27, 2013 at 4:21:55 pm
HDMI port
Use the HDMI port to connect a compatible HDMI display, TV, or projector. Mac Pro supports HDMI 1.4 to enable connections to UltraHD and 4K displays. The HDMI port supports the following resolutions.
1080p resolution at up to 60Hz
3840-by-2160 resolution at 30Hz
4096-by-2160 resolution at 24Hz
John Putch
on Mar 5, 2014 at 6:56:42 pm
I can't get the new Mac Pro to display any video out of the HDMI port. The system prefs sees it, but does not send video to the LCD monitor or any standard HDMI enabled TV. Has anyone else had this issue?
http://www.putchfilms.com
http://www.route30too.com
http://www.mojavephonebooth.com
