How to add newly imported audio - as a new storyline/angle to existing multi cam Project??
Babylon Slim
on Dec 18, 2013 at 1:03:34 am
I have a 6 camera multi cam Music Video Project I have been working on in depth for 5 days. The "band" has sent me a new & improved .wav file to replace the audio I have been working with on one "song". I have imported it into the event, cannot figure out how to add it as a new angle (that I will manually sync on the timeline) and then make it the active audio monitor angle. I see ways to "connect it" but not how to have it appear in the 6up display & on its own story/time line in the precision editor. This is like reinventing the wheel. I am losing mu mind. Please help?
Fascism should more appropriately be called Corporatism because it is a merger of state and corporate power.
- B. Mussolini
Jeff Kirkland
Re: How to add newly imported audio - as a new storyline/angle to existing multi cam Project??
on Dec 18, 2013 at 1:40:21 am
You can manually add an angle in the Angle editor, sync it up (manually or automatically) and then set that as your new default angle. I think you'll still need to go back to your project and set the audio angle to the new one though.
Alternatively, you could just add it as a track connected to your project and turn off the sound in the multi-track clip.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Babylon Slim
on Dec 18, 2013 at 1:45:56 am
Thanks, How do I manually add a new angle? I have tried selecting it, dragging, etc. I am still stumped. Can you explain it as if I was a child?
Jeff Kirkland
on Dec 18, 2013 at 1:49:13 am
In the angle editor, you should see a downward pointing triangle next to the angle name. Select that, then choose add new angle (amongst other nifty options that menus gives you).
Babylon Slim
on Dec 18, 2013 at 1:56:16 am
Thank you. I need to take a break & eat. i swear knew that & forgot it. Thank you for your quick response... Take Care.
