FCPX Cross Dissolve glitch ???
craig flood
on Dec 5, 2013 at 1:47:24 am
Hey Guys,
Not sure if anyone else has had this problem but FCPX glitches on me sometime when I add a cross dissolve to certain clips. I haven't found any rhyme or reason to it.
Below is a screen grab of the timeline
6862_screenshot20131204at4.57.24pm.png.zip
Here is a quick export of it happening, once at the beginning of the shot and another happening at the end.
Cross Dissolve Glitch
You'll notice that as the image is in the process of dissolving to the next image, the original image that should be leaving jumps back in real quick at the end of the dissolve.
Does anyone know why it does this? I can't seem to figure it out.
THANKS!
CRAIG
Jeff Kirkland
Re: FCPX Cross Dissolve glitch ???
on Dec 5, 2013 at 2:25:23 am
I'd guess a corrupt render file? Try deleting your render files and see if goes away. I've had more than one weird glitch cured by doing that.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Claude Lyneis
on Dec 5, 2013 at 5:01:14 am
I have had the same sort of problem, but never figured it out.
Nick Toth
on Dec 5, 2013 at 1:55:35 pm
I've seen that happen when moving transitions around. I think it's a "leftover"render file because deleting render files has always cured it for me.
anickt
Andy Neil
on Dec 5, 2013 at 4:44:25 pm
Agree with the others that it might be a corrupt render file. Let me ask you a question, do you have background rendering turned on? Try turning it off. Dissolves are realtime effects anyway and if you're editing and moving things around, only giving FCPX a second or so at a time to render effects as you work, it's possible that makes it more likely to have a corrupt render.
Andy
http://www.timesavertutorials.com
