Consolidate Project to new drive not working right
Elahn Zetlin
on Dec 4, 2013 at 4:07:02 pm
I wish to copy a project from one drive to another to be able to edit on a second computer.
I select the project and go to consolidate project media.
I select project and used clips as I just want to copy what media that has been used, not everything else.
On the new drive I see that it has created a folder of reference clips, not actual media clips. As well they are of everything, not just the used media clips.
Any thoughts?
Bret Williams
Re: Consolidate Project to new drive not working right
on Dec 4, 2013 at 4:57:36 pm
I think you meant you duplicated a project. That's what makes a copy to another location. In any case, afterwards, open the new event and select all and choose file>organize event files.That will replace the aliases with copies of the originals.
Jeremy Garchow
on Dec 4, 2013 at 4:59:49 pm
Yes. Don't use Consolidate. It does not mean what you think it means and it's confusing.
What you want is to select the Project, Duplicate it, and choose "Duplicate + Used Clips" and select the destination drive.
Once it is done copying (which should be very quick) use the "Organize" command on the Event.
This will bring a hard copy of the material in to the Event.
Jeremy
Jeremy Garchow
on Dec 4, 2013 at 5:00:10 pm
Oops. Bret beat me to it.
Bret Williams
on Dec 4, 2013 at 5:03:38 pm
Yep. What do I win?
Jeremy Garchow
on Dec 4, 2013 at 5:18:02 pm
[Bret Williams] "Yep. What do I win?"
Bret Williams
on Dec 4, 2013 at 6:30:57 pm
Ah, ummmm, errr, well.... Thanks?
