cannot relink files in FCPx
Pam Picard
on Dec 3, 2013 at 7:14:49 pm
I'm working on a project that is completed. Before we export, it was decided some of the shots needed to be replaced with new color corrected shots.
I have the new files, but these files no not have audio. When I try to relink them into the project, I receive an error message saying the files are incompatible due to the fact that the original files had audio, and the new ones do not.
John Fishback
Re: cannot relink files in FCPx
on Dec 4, 2013 at 10:56:45 pm
One of the frustrations of FCPX. If one bit of metadata changes, FCPX considers it a new file. You can't reconnect like in Legacy. I don't know if anyone has a workaround, but I'd import the new files and Replace the old with the new (Replace from Start).
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
© 2018 All Rights Reserved
