Viewing Time Remapped clips or effects on Project timeline
Jordan Mena
on Nov 15, 2013 at 8:01:23 pm
Is there a way yet to be able to visually see if a clip has been time remapped or has an effect on it at a glance? I noticed after I speed up or slow down a clip after I close the remap bar if I open it again it makes the clip go back to 100%. unless I use Command+R. I don't want to accidentally undo a speed change by mistake.
I liked the button in FCP7 that raised the clips up on the timeline so I could visually see which clips had effects or speed changes. It should be in X no?
thanks!
Jordan Mena | Editor | Colorist | Producer
Los Angeles, CA
jordanmena.com
James Cude
Re: Viewing Time Remapped clips or effects on Project timeline
on Nov 15, 2013 at 8:15:18 pm
Select All Clips- then Command R for Show/Hide Retime Editor.
Bret Williams
on Nov 15, 2013 at 8:59:42 pm
It shouldn't be going back to 100% unless you specify for it to.
