how to detach audio from multi clip
anita sancha
on Nov 10, 2013 at 11:23:01 am
Ive edited some multi clips and now having edited the visuals I need to detach edit so that i can run one audio over the other . if i make it into a compound clip, and I break apart the audio.... it keeps crashing with Dispatch queue: com.apple.main-thread..
Thanks for all your help
Anita Sancha.
http://www.anitasancha.co.uk
Jeremy Garchow
Re: how to detach audio from multi clip
on Nov 10, 2013 at 1:42:22 pm
You can't.
You have to tediously find the source and add another instance of the audio to the timeline.
anita sancha
on Nov 10, 2013 at 5:05:53 pm
thats what I've been doing!!!!! very annoying. but thanks
Anita Sancha.
Charlie Austin
on Nov 10, 2013 at 7:49:14 pm
[Jeremy Garchow] "You can't.
You have to tediously find the source and add another instance of the audio to the timeline."
This is something that has annoyed folks for a while. Hopefully it'll change with the next version...
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Loren Risker
on Nov 11, 2013 at 9:07:56 pm
You can also turn that section into a compound clip and detach that way.
OutOfFocus.TV - Original series, music videos, mini-docs.
Matt Trubac
on Nov 15, 2013 at 12:38:26 pm
Just cut out and copy the section of the multiclip with the audio you want, or match frame and edit it back in. Between audio component view and expanded audio view you should be able to do what you need. Drag it below the primary storyline, or leave it above and turn opacity to zero. Pretty much what you want to do by detaching I think.. Just make it so the video doesn't show.
