fcpx can't find usb3 disk
Björn Obenius
on Nov 4, 2013 at 1:47:45 pm
on a new iMac fcpx 10.0.9 cant find the attached usb3 disk. To the disk I have copied an Event and a Project file by dragging them from the internal hdd. The external disk is visible in Finder. What do I have to do to make it visible inside fcpx?
Thankful for any suggestion, Björn, Toreboda, Sweden
Jeremy Garchow
Re: fcpx can't find usb3 disk
on Nov 4, 2013 at 2:33:18 pm
What format is the drive? It should be OS Extended. You can check this in Disk Utility.
If OS Extended, check your Borwser prefs in fcpx and make sure that "sort by hard drive" is on. I can't remember the exact term, but the controls are right below the browser in the left corner.
Also, your events and projects need to be in a folders marked "Final Cut Events" and "Final Cut Projects" on the root level of the external drive.
