may I say ?
Osmani Tellez
may I say ?
on Nov 3, 2013 at 12:22:37 am
I just found out...that you can´t copy properties of text....or i can´t find it.
just made a bunch of subtitles for a 6 min clip...but..if i want to try a new font, or chance the size a bit..looks like it has to be done manually one by one...I think it could be a very useful tool and maybe something to ask apple about..i mean the pros...hehehe..and maybe is not to much to implement,,
have you had this same issue?
FCPX 10.7, Motion 5. Canon 5D mark II, T2i, T3i.
Osmani Tellez
Re: may I say ?
on Nov 3, 2013 at 12:33:32 am
my bad...i just found a way...selecting all of your text you can change properties of them all in the inspector tab..have way thru i thought about trying this..and voala..
Bret Williams
Re: may I say ?
on Nov 3, 2013 at 6:56:28 am
As long as they're the same it seems to work. But if you select 10, and 9 are a certain font, and 1 is a different font (or size) then seems that it's a no go. So if you have something like subtitles, you want to make sure you change them as a batch.
