Can't delete compound clips from the Event Browser
nick harambee
on Nov 2, 2013 at 9:59:40 pm
I am unable to delete any compound clips from my event library. I see the following error:
I am sure that these compound clips are not currently in use in any project, and I have restarted the application and still can't delete them.
What else can I try to get rid of them?
Nick
James Ewart
Re: Can't delete compound clips from the Event Browser
on Nov 3, 2013 at 2:08:17 pm
I had this. I am fairly certain you will find a little bit of the compound clip in one of your project timelines if you look very carefully.
nick harambee
on Nov 3, 2013 at 3:36:33 pm
Thanks. I'm sure the clips are not in use. I have now been led to believe this is a bug. I have hidden all of my projects and still can't delete any clips from events.
James Ewart
on Nov 3, 2013 at 6:14:46 pm
All I can say is I had the exact same problem and it drove me nuts and I found one frame from a compound clip in one of my timelines.
May well be different for you.
what would be useful would be a shortcut "reveal in project timeline"
Eric Suntken
on Aug 2, 2018 at 7:43:55 pm
Thanks so much, James. This was driving me crazy because I was sure the clip was not in use. However, when I zoomed into my storyline as much as it would allow, I found a frame from the clip that was previously undetectable. I appreciate your help!
Doug Metz
on Aug 3, 2018 at 2:00:46 pm
[James Ewart] "what would be useful would be a shortcut "reveal in project timeline""
+1
If Final Cut knows that a clip in use somewhere in a particular Library (even if it isn't in the active Project), it should be possible to identify which Projects are using the clip.
Sending feedback now.
Doug Metz
Anode
