Post Haste and FCP X
Oliver Peters
on Oct 17, 2013 at 10:48:08 pm
Is there a way to set up a template with Post Haste to work with FCP X?
- Oliver
Orlando, FL
http://www.oliverpeters.com
Jordan Mena
Re: Post Haste and FCP X
on Oct 17, 2013 at 10:51:03 pm
Yes. Using it now. Works great with XSan
Jordan Mena | Editor | Colorist | Producer
Los Angeles, CA
jordanmena.com
Oliver Peters
on Oct 17, 2013 at 11:23:55 pm
But how do you set up the template? One for X is not included with the installer. I presume you'd start with a blank "New Event" file using the right folder structure and build that into the template file. Could you be more specific? Thanks.
- Oliver
Orlando, FL
Jon Chappell
on Oct 18, 2013 at 2:04:40 am
FCPX has very specific requirements in terms of the locations of project and event files. It also has issues if two projects or events have the same ID.
So for these reasons we don't recommend using Post Haste to directly manipulate project files. We recommend you use it to manage media only or create templated FCP XML files that can then be imported into FCPX.
My software:
Pro Maintenance Tools - Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
Pro Media Tools - Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
More tools...
Oliver Peters
on Oct 18, 2013 at 2:17:58 am
[Jon Chappell] "FCPX has very specific requirements in terms of the locations of project and event files. It also has issues if two projects or events have the same ID."
I was wondering if you could create a template that placed a blank "New Event" subfolder and event data file into a "Hidden" folder. I presume a user could create one and then import that into a new, custom template. You'd have to manually move it from there into the proper FC Events folder when actually working on it. I realize this sort of defeats the purpose, but it's a thought.
- Oliver
Orlando, FL
Jon Chappell
on Oct 18, 2013 at 2:42:18 am
You can't do that because FCPX won't like more than one event having the same ID. I'd recommend using XML files in the template then importing into FCPX for each project.
Also, future features will benefit from the data being in XML format.
My software:
More tools...
Oliver Peters
on Oct 18, 2013 at 2:45:50 am
[Jon Chappell] "You can't do that because FCPX won't like more than one event having the same ID"
But wouldn't that be updated when a PH project name is assigned? Or do you mean the "current version" file would have the same ID, because it always starts from the same template dummy file?
- Oliver
Orlando, FL
Jon Chappell
on Oct 18, 2013 at 2:48:25 am
The ID is inside the CurrentVersion file so it doesn't change if you create a copy outside of FCPX.
My software:
More tools...
Oliver Peters
on Oct 18, 2013 at 12:10:59 pm
Thanks. That's what I was afraid of.
Oliver
Orlando, FL
Jordan Mena
on Oct 18, 2013 at 6:47:27 pm
yes, sorry. We use post haste to create our Assests folder and location for our Events. We then create a event template inside FCPX under the User and duplicate that for other projects (events).
Los Angeles, CA
jordanmena.com
