2/3 Questions 1080p to 1080i and FCPX FHA
Dan Rayner
on Oct 11, 2013 at 1:50:01 pm
Hi guys
I have to deliver a music video in ProRes 422.
The footage was shot in 1080p and delivery is required in 1080i FHA.
Firstly, do I have to do anything to the footage to make it FHA?
Secondly, how do I convert in Compressor or export from FCPX at 1080i
Thirdly(!) Any idea how to add a 10 sec countdown leader in FCPX?
Many thanks in advance people.
Dan
Andy Neil
Re: 2/3 Questions 1080p to 1080i and FCPX FHA
on Oct 11, 2013 at 3:17:34 pm
What does FHA mean? I've not heard that before.
Andy
http://www.timesavertutorials.com
Jari Innanen
on Oct 11, 2013 at 3:28:35 pm
Last time I heard the term it was used with SD-tape material.. FHA= Full Height Anamorphic?
Dan Rayner
on Oct 11, 2013 at 3:45:33 pm
Exactly, Full Height Anamorphic. I don't think it applies to my 16:9 1080p footage but it is specifically listed in the delivery format requirements for HD content "16:9 FHA".
I just want to make sure that the file I send them is correct first time.
Bret Williams
on Oct 11, 2013 at 6:19:55 pm
Federal Housing Authority?
Wouldn't Full Height Anamorphic refer to an SD version? HD isn't anamorphic. Even anamorphic formats like DVCProHD aren't technically called anamorphic.
I guess I'd start by making a 1080i sequence and going from there. That will accommodate 24p, 30p, 60p footage without any conversions needed. It'll add the pulldown to any 24p, and 60p will get each frame mapped to a field. 30p just gets each frame duplicated to two fields.
Dan Rayner
on Oct 11, 2013 at 6:40:13 pm
If it wasn't in the UK I'd agree that it must be the Fed Housing Authority!
But I think you're right, hence my confusion on seeing it on the spec sheet.
Many thanks for your help.
gary adcock
on Oct 11, 2013 at 6:26:49 pm
[Dan Rayner] "The footage was shot in 1080p and delivery is required in 1080i FHA."
That is an errant way to describe the image.
It should really be called full 16x9 or full 1.78 aspect.
They just want to avoid the black bars top and bottom that happen when people shoot with RED's 2:1 aspect ratio
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
Follow my blog at http://www.garyadcock.com
Or follow me on Twitter
@garyadcock
Dan Rayner
on Oct 11, 2013 at 6:38:43 pm
Thanks Gary. And do you think they'll have issues if letterboxing is used for aesthetic purposes?
gary adcock
on Oct 11, 2013 at 7:00:49 pm
[Dan Rayner] "do you think they'll have issues if letterboxing is used for aesthetic purposes?"
With the way the spec was written, I would assume so.
Exception might be if you used a color other than black for it.
Note too that that also might refer to something called AFD ( auto file description) that tags horizontally compressed media like HDV and DVCProHD content to play in proper wide screen aspect ratio in HD.
just a guess with out reading thru all the specs.
gary adcock
Studio37
Chicago, IL
@garyadcock
Dan Rayner
on Oct 11, 2013 at 8:11:25 pm
Thanks again Gary - very useful info.
Dan
