Premiere Pro XML to FCP X
Jeffrey Farrell
on Oct 9, 2013 at 12:52:24 am
Hello, I output my edit XML from Premier Pro CC and tried to load it into my Macs FCP X and it would not even recognize it as readable. Any tips?
Jeffrey S. Farrell
DP - Filmmaker
8K Productions
http://www.8kproductions.com
Utah Camera Rental Services
Jeremy Garchow
Re: Premiere Pro XML to FCP X
on Oct 9, 2013 at 2:18:36 am
You need to translate it using 7toX.
http://assistedediting.intelligentassistance.com/7toX/
Jeffrey Farrell
on Oct 9, 2013 at 4:25:01 am
I'm trying to go from PC Premiere Pro to a FCP X machine. Not FC7 to X.
Is it even possible to take a project from PC Premiere Pro to a FCPX?
Jeffrey S. Farrell
DP - Filmmaker
8K Productions
James Cude
on Oct 9, 2013 at 5:33:00 am
Premiere Pro CC writes to FCP7's XML format so the advice you received above is valid.
Jeffrey Farrell
on Oct 9, 2013 at 6:09:45 pm
Thank you all!!
Jeffrey S. Farrell
DP - Filmmaker
8K Productions
