Caption in My Timelines don't disappear
Nicolas Vallejo
on Oct 8, 2013 at 7:01:53 pm
Is there any way to have the footage appear on my timeline instead of captions. This just appeared randomly. Every file is in its place.
James Cude
Re: Caption in My Timelines don't disappear
on Oct 8, 2013 at 7:20:58 pm
Huh- can you explain that a little more clearly?
Nicolas Vallejo
on Oct 8, 2013 at 7:24:21 pm
Essentially, I see that in my time line when I should be seeing the footage.
James Cude
on Oct 8, 2013 at 7:32:53 pm
Please describe the entire issue clearly- pretend like we're not sitting in front of your computer with you.
Nicolas Vallejo
on Oct 8, 2013 at 7:35:43 pm
Essentially, there's gaps in how my timeline is showing the clips. It shows the image from the footage in some parts, and in other parts it shows a caption/missing clip, or however you want to call it.
Here's another image:
Sandeep Sajeev
on Oct 8, 2013 at 7:41:08 pm
Ok, I see. Is it only doing this for images? Or are those image sequences that you've got there?
Nicolas Vallejo
on Oct 8, 2013 at 7:45:11 pm
It's doing it randomly, only for images. I tried clip height thing and it didn't work.
Sandeep Sajeev
on Oct 8, 2013 at 8:00:35 pm
Close FCP and delete your render files. Then relaunch and it will rebuild your Project thumbnails.
Nicolas Vallejo
on Oct 8, 2013 at 8:12:01 pm
That didn't fix the problem.
Sandeep Sajeev
on Oct 8, 2013 at 7:39:35 pm
There is a little toggle on the bottom right (your right side) where you can adjust the clip height etc. Pick one of the options that shows you the Video filmstrip.
I'm not in front of a machine at the moment or I would post a screen grab. You can google adjust Clip Height to see which button I'm referring to if you can't find it.
Best,
Sandeep.
James Cude
on Oct 8, 2013 at 8:40:36 pm
Are you using Compound Clips- those look like Compound Clips...
Nicolas Vallejo
on Oct 8, 2013 at 8:44:16 pm
Nope. They're not compound clips.
James Cude
on Oct 8, 2013 at 8:46:35 pm
Are you sure? You shouldn't see that icon in your thumbnails if they are original media. I'd suggest copying and pasting the whole edit into a new timeline- that often clears out weird stuff.
Nicolas Vallejo
on Oct 8, 2013 at 8:50:49 pm
New Timeline. Bingo. Merci.
James Cude
on Oct 8, 2013 at 8:56:58 pm
Sure thing- glad to hear it.
