Bug with dissapearing markers on the primary storyline
Mathieu Ghekiere
on Sep 25, 2013 at 6:38:07 pm
So after loosing markers on my timeline for the second time, I finally know where the bug is, and I could reproduce it, and I also made a screen recording. I filled in feedback to Apple, but I also wanted to post it here, to make people aware of the issue and hopefully not experiencing the same.
If you ever had an edit session with a client where you depended on the information you put in your markers, it can cost you a lot of time, money and energy if you loose all your markers...
So!
The problem: Dissapearing Markers on the Primary Storyline
Details:
Although we like the benefits of the magnetic timeline, for certain complex edits we do, we have to do them as connected clips, to avoid magnetism. We have to work with layers anyhow, but in those edits we only leave gaps in the primary storyline for specific editing reasons.
Anyhow, we have a primary storyline full of gap clips (not one big long gap clip, but they are cut in multiple clips). We have connected clips on all of those.
We do put our markers with to do's etc on the primary storyline.
When you put a dissolve between 2 connected clips, it automatically becomes a connected storyline, you cannot change this.
But here comes the bug: if you select a clip in the connected storyline, and do the shortcut LIFT FROM STORYLINE, suddenly ALL your markers dissapear on the primary storyline, and it also made one big clip of all the different gap clips on the primary storyline (which explains the markers dissapearing as they were connected to those gap clips).
Pretty serious bug, and easily reproducable.
Here is a link to a screen recording showing the bug in action:
https://www.dropbox.com/s/6x5lswgt197bggt/BUG_MARKERS_FCPX_CROP%20-%20Broad...
Loren Risker
Re: Bug with dissapearing markers on the primary storyline
on Sep 25, 2013 at 7:45:06 pm
Great find! Thanks for sharing.
OutOfFocus.TV - Original series, music videos, mini-docs.
Charlie Austin
on Sep 25, 2013 at 7:53:50 pm
[Mathieu Ghekiere] "Pretty serious bug, and easily reproducable. "
Honestly, i don't think its a bug… it's a feature. For your workflow, yes, it's bad. For me, I'f I've lifted clips from a storyline, I want all the gap clips to reunite.
If I need fixed markers throughout a cut, since ya can't have markers in the timecode/navigation bar, my solution was to make a long, silent audio clip. Add it to the timeline first so it "sticks" to the primary, and make sure it begins, and is connected, to the first frame of your timeline. Give it a unique role, uncheck that role in the index to disable it, and also minimize it using the button in it's Role in the index. Put your "sequence markers" on this clip. Voila! Markers that don't move, unless you want them to.
If you think you may want to cut the marker clip to pull it up, say if you cut out a section but want your markers beyond the cut to stay in sync… create a secondary containing the marker clip and you chop it and pull it up with everything else, but the secondary will alway be connected to first frame so it won't move. The markers will reference timeline position unless you cut the marker clip within the secondary and move it manually.
It's actually way better than "sequence markers" from the old FCP, since they stayed put no matter where you moved the clips underneath them that the markers may have referred to. :-)
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Ronny Courtens
on Sep 25, 2013 at 9:13:14 pm
I agree with Charlie.
You must understand that gaps are NOT clips and you should not work with gaps like you work with clips. Gaps are only useful when they are placed between clips. Sliced-up gaps (without any clips between them) don't have any use and they will always be joined by FCPX whenever it can. So you never should put markers on top of a sliced-up gap.
If you want to edit without using the Primary Storyline but you still want to put markers on it, just put a slug generator or an adjustment layer in the Primary. This will act as a regular clip to which your secondaries and CCs are attached and above which you can add markers.
- Ronny
Loren Risker
on Sep 25, 2013 at 9:17:05 pm
I agree that the workflow is questionable, but auto-deleting markers for any reason isn't acceptable.
Charlie Austin
on Sep 25, 2013 at 9:24:45 pm
[Loren Risker] "but auto-deleting markers for any reason isn't acceptable."
i agree with that, but when you are placing markers on something that, really, is not a clip at all, it makes sense. Gap is essentially a visual representation of nothing. If you want to use the primary only as a giant marker or scene separation reference then, as Ronny points out, you need to put a clip or something into it. Gap is not a clip - and, all due respect to the OP, this is not a bug.
James Cude
on Sep 25, 2013 at 11:12:31 pm
Yeah I could see why you'd do it this way but as a workflow it's not really the norm. If you *had* to do it this way- use a disabled clip instead of gap. That way your markers will be preserved but functionally it's going to look the same as the gap you're doing.
Also I think it would make way more sense to nest these compositions into Compound Clips instead of trying to force things into place with gaps all over the place.
Mathieu Ghekiere
on Sep 26, 2013 at 8:55:00 am
*double post
Charlie Austin
on Sep 26, 2013 at 2:33:34 pm
Hey Mathieu,
Great explanation of a your workflow... Oddly, I used to do staging, live audio and video projection, and in addition to the requisite trade/stage shows, I would occasionally work at one of these medical conferences. :-) Being a bit squeamish It was sometimes a challenge! I can only imagine what having to sift through all the footage is like. My hat's off to you, for the workflow *and* the work! :-)
Still, I actually find the fact that X "cleans up" cuts in gap to be very useful. So I still think a disabled generator cut into the primary would do just what you want. :-)
Mathieu Ghekiere
on Sep 26, 2013 at 10:11:19 pm
Hi Charlie,
that's exactly our plan. For us it's not a problem if we remind to do it at the beginning of the edit. We will have to do some tests, but I'm pretty sure in that case we won't have to worry about dissapearing markers.
Thanks again for the tip and kind regards,
Jeremy Garchow
on Sep 26, 2013 at 2:34:57 am
The certainly feels like it could be fixed by Apple if they wanted to. It is advantageous to have multiple gap clips in the primary sometimes.
My bigger question is why not use the primary?
Perhaps, put the audio in it?
James Ewart
on Sep 26, 2013 at 3:42:34 am
"Although we like the benefits of the magnetic timeline, for certain complex edits we do, we have to do them as connected clips, to avoid magnetism. We have to work with layers anyhow, but in those edits we only leave gaps in the primary storyline for specific editing reasons"
Why? What are those reasons please?
Am I correct in observing that you have just gaps on your primary storyline?
If so it looks a little to me like you may be trying to bypass the magnetism and edit in FCPX as if it were 7.
Is that the case?
Mathieu Ghekiere
on Sep 26, 2013 at 8:56:07 am
I very much think this is a bug: remember: I have 2 connected clips, which I just put a transition between. I have no choice but this to become a connected storyline (I get the 'logic' behind it, but I do wish Apple would make this optional). I select ONE clip in a CONNECTED Storyline, lift that clip from that same connected storyline, and suddenly FCPX decides to remove cuts in gap clips (and thus removing markers) in the primary storyline, which is a DIFFERENT storyline.
If it would have been a clip that I lifted from the primary storyline, I could see this logic happening (maybe not agreeing with it, but you could know something like this happen). This is just one shortcut, completely having an effect on a different storyline.
I don't think how anyone can not see this as a bug.
Ps, by just dragging the clip out of that secondary storyline, you do not get the bug.
That being said, I do appreciate the time, and efforts for everyone's reaction, and Ronny and Charlie, thank you for the alternative methods, I will make sure to check them out!
About our decision to leave the primary storyline out and just work with connected clips:
It's not aversion for the magnetism of the primary storyline. We like the advantages it gives, and we use it. But not when we do *these* edits. These are specific edits where we do things with a reason ;-)
So what are *these* edits?
We record medical procedures, sometimes up to 9 hours long (but ALWAYS continuous recordings of at least a couple of hours). We end up with about 6 Prores streams, timecode-locked. Not always do they all have sound. These often exist out of 2 camera-images, and the other 4 being medical monitors that are tapped. These can be pressures, an echo view of a heart, a fluroscopy, an any case: an image that is only logical for doctors, and not for editors. The only way we have to make sure that these images are in sync, is timecode, because we do not have a visual reference.
FCPX, as you know, does not have timecode overlays in the canvas or viewer, like FCP7 had.
If we put clips in the timeline in FCP7, and one would get out of sync, by accident, with the other streams, we would see it by the timecode overlays. Because we do not have a visual reference, we can NOT see on 6 hours of a black-and white medical image if something is a couple of seconds or minutes out of sync, but doctors can.
The way we work around this, is by making our source clips into compound clips with a timecode generator on them. We make sure the compound clips have the same timecode as the original. So then we have 6 big compound clips, each with a timecode generator on it. If we now drop them on the FCPX timeline, and we make them all small so we have one image with 6 picture-in-pictures, all of these images have a timecode generator so if something would get out of sync, we immediately see it just by the timecode in the frame.
We do not do multicam for these edits. It's not that the doctors want to see this OR that, they often want to see multiple images at the same time.
So we put this compound clips as connected clips on a sequence timeline, that again, has the same timecode as the originals. Why? What we do then is, we send the doctors a copy of this hour-long case (or they come and do it with us at the studio) so they see everything. They need to cut this hours-long video down to a 20 minute video to show on a congress. They need to see everything to make a selection of what is important.
So, they send us back often a timecode copy. It's a word-document that says:
10:45:98:10 - 10:45:98:10 I want to see Cam 1 and Echo (for example).
I will have a list that has hundreds of these selections. If I make sure that my timecode of my sequence matches up with those of my compound clips, and IF I only put them on the timeline as connected clips (so why do we have gaps? We just do Q, Q, Q to get them all above each other on the timeline), then we do not LOOSE the time relationship between the connected clips and the sequence timecode. Why is this important?
If I have to go trough hundred clips, I cannot skim always to the right frame and cut. It would take days to cut it. No, I look at the timecode in the document, type in the dashboard, and make the cuts. (pity we still cannot copy and paste timecode in the canvas or dashboard, but oh well…)
If I now blade all, I have this selection where a cut on 10:00:00:00 in the dashboard, I also makes a cut on 10:00:00:00 in the originals. I have to keep all the streams, because it happens often that we afterwards get the remark: oh in that selection I also want to see that. It doesn't take a lot of time to just leave an extra stream and put the visibility off, then to add it afterwards back in.
That's why we work with connected clips. We cannot loose the relationship with the source timecode. And because these are medical monitors, it is very dangerous to loose sync without visual reference because chances exist you won't notice. And then we work with connected clips in a way of being able to cut very fast trough time codes that we type in the dashboard.
We then do blade all, make the selection, and if it's a selection the doctor doesn't want to use, we put the visibility of all layers of (including the primary). Because I bladed all, including the primary, if I change the visibility on these 6 streams, it's only on the selection of for example 2 minutes I made, and not on the 5 hours of material after that selection.
I then also make a small marker on the primary storyline (gap) of that piece with markers. For instance, if I put 3 of the 6 layers visible, I have a marker saying: 'this one should be big, the other 2 should be small'.
Once you use the primary storyline with a video image you use to also cut, there is a lot of chance, because of the magnetism, that you loose the relationship between timecode of your source, and timecode of your sequence. And because in a way, you *only* have your sequence timecode in the dashboard of X it's pretty dangerous.
This method which included a couple of work-arounds in comparison with our workflow in FCP7, but it also included a couple of extra benefits. (we can drag a piece of primary storyline with gap to another place, and immediately have all those layers going with it, this is when we can use the magnetic timeline to our benefit.) We can also, if there is a patients name that needs to be covered from a medical monitor for privacy reasons, we adjust it in the compound clip, it ripples trough to our edit. Just before export, we just open the compound clips, put out the visibility of the timecode generators, it ripples trough to all our edits, and we can export. Do they need changes? We just put the visibility on again, and we can start editing again.
In FCP7, using only one timecode generator would have a lot of impact on performance and export times. In FCPX, we use 6 of them, unrendered, and play it all back at the same time. It's great.
Now it is easy to afterwards say: just use a title or something to put your markers on. It is a good idea, and I will do so in the future (thanks again). But we never had issues with this complete workflow or way of editing, on the contrary, it was the only way we could do this kind of edits in FCPX (and enjoy X's many other benefits) without getting into a mess or loosing too much time 6x 9 hours of material and making sure everything stays in sync. It works.
The only reason why would now change gaps to titles, or do them on a separate adjustment layer, is because X decides, if you lift a clip from a connected storyline, it immediately deletes cuts on the primary storyline, although I cannot fantom any reason to do so or any logic behind it. So yes, I still think this is a bug. And I am not a fan of connected story lines (they serve their purpose, but I'm just talking about - again - these specific edits) but there is no way to avoid them if you want to make a transition between 2 connected clips.
Jeremy Garchow
on Sep 26, 2013 at 6:21:12 pm
Me too. The behavior is inconsistent as you mention here:
[Mathieu Ghekiere] "I very much think this is a bug.... Ps, by just dragging the clip out of that secondary storyline, you do not get the bug. "
Thanks for you explaining your workflow. I see why you do it the way you do. An honest-to-goodness timecode READER would help so much.
Jeremy Garchow
on Oct 2, 2013 at 4:12:30 pm
[Mathieu Ghekiere] "We do not do multicam for these edits. It's not that the doctors want to see this OR that, they often want to see multiple images at the same time. "
I thought about this a bit after another post triggered the idea.
The nice thing about multicam is that you can see timecode with the timecode overlay.
I know you need to see all angles, so why not make a multicam clip of the necessary material, duplicate the mulitcam clip 6 times, switch each clip to the appropriate angle, and then rearrange the angle banks to show one of the appropriate angles in a 2 angle view, then add the clips to a projects and arrange the 6-up picture in picture view?
So instead of 6up compound clips, you'll have 6up multicam clips, and you'd be able to see tc overlays in the angle viewer on skimming?
Jeremy
James Ewart
on Oct 2, 2013 at 4:19:07 pm
My solution would be to get a tripod and shoot the multi cam window off the screen.
A bit Heath Robinson perhaps.
Mathieu Ghekiere
on Oct 4, 2013 at 2:03:12 pm
Hi Jeremy,
when we started with figuring out how to edit this kind of stuff in X, that was actually my first thing to try out.
You have to know that when we record a feed, we have for instance a couple of hours long feed, broken up in 30-minute clips, because a Pix260 does that.
So we have to put them together. So far so good. But some of them also need to have a matte applied, because a patient's name is on a monitor, and for privacy reasons, that kind of stuff needs to be blanked out.
This is where compound clips become very handy, just put a matte on it, and it ripples trough to everything.
I think there were a couple of other reasons too, why I opted out of trying to have Multicam-clips for our purposes, but I forgot.
I think it was a bit easier and faster visually to see if sync got wrong, with timecode generators above it instead of timecode overlays in the multicam generator.
You need to have your View Angles open constantly if you want to see sync. Now we can just work with the viewer. That also helps.
Regards,
Jeremy Garchow
on Oct 4, 2013 at 3:58:34 pm
That makes sense, Mathieu.
It's too bad you can't take multicam down to One View, then you could have the view set for each angle and have the best of both worlds.
Thanks for sharing your info, it's always cool to see how people approach these types of issues.
I still want a tc reader filter. ;)
Jeremy
James Ewart
on Oct 8, 2013 at 3:51:46 pm
I am wondering whether this plugin would help you in any way? Just found it myself.
http://www.fcpeffects.com/collections/new-stuff/products/screen-splitter
Just a thought.
Mathieu Ghekiere
on Oct 9, 2013 at 2:09:24 pm
Well, we use Pipinator together with Squidborders, that gives us great results.
This plugin would maybe make the first timecode copy a bit less work, but not sure if it would be enough to justify the cost, because we often have sources with different aspect ratios.
Thanks for the heads up, I'll give it some further look, though.
James Ewart
on Sep 26, 2013 at 9:09:01 am
Thank you for an interesting insight into another world.
Mathieu Ghekiere
on Sep 26, 2013 at 9:09:58 am
Haha, you and me both ;-) it IS another world.
Mathieu Ghekiere
on Sep 26, 2013 at 11:47:33 am
I had a complete post here with my explenation about the how and why of our workflow. I got a message that the post is under moderation, but I don't know why.
James Ewart
on Sep 26, 2013 at 11:49:42 am
That is weird...
Mathieu Ghekiere
on Sep 26, 2013 at 1:12:38 pm
Just to try again:
"I very much think this is a bug: remember: I have 2 connected clips, which I just put a transition between. I have no choice but this to become a connected storyline (I get the 'logic' behind it, but I do wish Apple would make this optional). I select ONE clip in a CONNECTED Storyline, lift that clip from that same connected storyline, and suddenly FCPX decides to remove cuts in gap clips (and thus removing markers) in the primary storyline, which is a DIFFERENT storyline.
The only reason why would now change gaps to titles, or do them on a separate adjustment layer, is because X decides, if you lift a clip from a connected storyline, it immediately deletes cuts on the primary storyline, although I cannot fantom any reason to do so or any logic behind it. So yes, I still think this is a bug. And I am not a fan of connected story lines (they serve their purpose, but I'm just talking about - again - these specific edits) but there is no way to avoid them if you want to make a transition between 2 connected clips."
Mathieu Ghekiere
on Feb 18, 2014 at 5:20:16 pm
FYI this bug has dissapeared in FCPX 10.1.
OW and Another bug that has dissapeared is that if you change the scale of a clip in the viewer trough the transform tools, it now immediately updates in the inspector.
