T Tool of 7 also in X?
Sascha Engel
on Sep 22, 2013 at 6:42:15 pm
Hi everybody,
Just spent bother day in editing the new conquered X application.
One Q came up: how can I select single or multiple tracks back or forward in the TL from the cursor point on (like in FCP 7 with T)?
Thanx.
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Andreas Kiel
Re: T Tool of 7 also in X?
on Sep 22, 2013 at 8:25:02 pm
use roles.
-andreas
Spherico
http://www.spherico.com/filmtools
X-Files Pro, tools for working with FCPX
http://www.spherico.com/filmtools/X-Files/index.html
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Sascha Engel
on Sep 22, 2013 at 8:30:36 pm
Wie kann mir Roles da helfen?
Z.B.: Ich moechte alle clips im Projekt con einer bestimmten Stelle nach rechts forward selektieren um sie so also Gruppe zu verschieben, so dass ein Loch ensteht, in das ich z.b. etwas einsetzen moechte.
Ich habe diese Funktion in FCP 7 andauernd verwendet.
LG,
Sascha Engel
Oliver Peters
on Sep 22, 2013 at 8:46:07 pm
There is no T or Track Tool. In this case you have to "think Avid". Insert a gap and then set the duration of the gap. This will slide all subsequent clips to the right thanks to the magnetic timeline. That's the way Media Composer has done it for years prior to their own Smart Tool addition.
You can also use the timeline index to select all clips after a certain point. Then click the P key for Position mode and drag the selected clips to the right. A gap is automatically created in the vacant space.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Craig Alan
on Sep 22, 2013 at 11:14:49 pm
[Oliver Peters] "You can also use the timeline index to select all clips after a certain point. Then click the P key for Position mode and drag the selected clips to the right. A gap is automatically created in the vacant space.
Not that your were talking to me. But thanks for that tip. Really a cool way to add a scene in a crowded timeline without screwing things up and you can always delete any excess gap when you are finished with the additional scene. I suppose you could also create a new timeline, work on the new scene and insert it when you are ready. But this method helps have control over what is being rippled down the timeline and you can check the edit before during and after the changes to be sure nothing has gone out of sync or messes with the sequence of shots.
I'm finding the index more and more useful, particularly if I named clips in a meaningful way.
Mac Pro, macbook pro, Imacs (i7); Camcorders: Panasonic AG-HPX170/AG-HPX250P, Canon HV30/40, Sony Z7U, VX2000, PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Oliver Peters
on Sep 22, 2013 at 11:24:26 pm
[Craig Alan] "Not that your were talking to me. But thanks for that tip. Really a cool way to add a scene in a crowded timeline without screwing things up"
Glad to be helpful.
- Oliver
Orlando, FL
Sascha Engel
on Sep 23, 2013 at 3:53:09 am
Good one. Thanx!
Sascha Engel
Bret Williams
on Sep 23, 2013 at 2:29:27 pm
[Oliver Peters] "That's the way Media Composer has done it for years prior to their own Smart Tool addition."
Only works that way if you have all tracks selected or have sync locks on. I thought I was the only one that worked in Avid with sync locks on 99% of the time. When I switched to legacy I had no problem adapting because it functioned, at least ripple-wise, like Avid with sync locks on. If you only wanted to ripple single tracks in FCP legacy, you had to lock the other tracks. Makes sense to me. Of course X is some sort of discombobulated hybrid of those two.
James Ewart
on Sep 25, 2013 at 7:50:51 am
That is an excellent tip thank you...sometimes inserting gaps can be a bit of a pain for some reason
Jeremy Garchow
on Sep 23, 2013 at 12:16:20 am
[Sascha Engel] "One Q came up: how can I select single or multiple tracks back or forward in the TL from the cursor point on (like in FCP 7 with T)?"
This comes up every once in a while.
This is certainly, where the X primary storyline method differs from tracks.
My question to you is, what are you trying to do exactly
I know, it sounds crazy, X is stoopid, blah blah blah, but your answer will make a difference on what needs to be done.
Sascha Engel
on Sep 23, 2013 at 3:56:46 am
@ Jeremy: I found the track tool in 7 tremendously helpful I I wanted to insert a space somewhere in certain place on the TL, so ii could insert material there.
Sascha Engel
Bill Davis
on Sep 23, 2013 at 5:15:48 am
Oliver's way above is great if you have a lot of complexity going on and want to carefully preserve the same. . But if you only want to slide everything downstream quickly and simply - and you don't yet have a lot of complexity built, just place your cursor on the primary here you want the gap, Blade all to form a new connected group (or not as you need), then tap Option W to Insert a gap at that point. Then drag the tail of the gap to make the space as long as you like.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Jeremy Garchow
on Sep 23, 2013 at 3:38:08 pm
Then a gap is the way to go, as has been mentioned.
Another thing to do is to select the first clip you want to move in the primary, shift click that last clip in the primary (which, in turn, selects all primary clips in between the first selected clip and the last clip), and then type "+1." which will shift everything from the selected clip down 1 second, and put a 1 second gap in the primary before the first selected clip. You can, of course, choose to enter whatever time you want, 10 second, 2 hours, etc. You won't have to worry about selecting the connected clips as they will move along with the primary clips.
Just an alternative if you like driving by keyboard like I do.
James Ewart
on Sep 25, 2013 at 8:03:38 am
My journey with FCPX only really began for real once I grasped the Gaps thing. Until then I was battling the software.
Use of Gaps is fundamental to the way I work now and i I were to write a manual, chapter one paragraph one would be to point out that you have to get your head round and use Gaps.
That said I seem to recall Bret does not use them much so it depends on the way you think I suppose.
