Broadcast Safe Color Correction - trying to Blowing out whites
brad hilton
on Sep 18, 2013 at 9:18:46 pm
I couldn't find a proper section for this and since I'm using FCPX I'd figured I'd ask here. I am finishing up an Ad that will broadcast and I'm trying to get a certain look. I want some area's to be overblown with a flare type look. The problem I run into is that I have my look, I add the broadcast safe filter, or try to tune down the white clipping with the color corrector, and it looks like crap.
Is it just a matter of playing and tweaking to get something close to what I want? Or does anyone have any tips? How do movie's and tv shows that use strong lens flares or blowouts not cause problems?
Oliver Peters
Re: Broadcast Safe Color Correction - trying to Blowing out whites
on Sep 18, 2013 at 9:54:55 pm
Make sure the broadcast safe filter is "downstream" of everything. You can do this by adding a adjustment layer generator as a connected clip (search for free ones or use Basic Title and remove any text) and then apply the safe filter as an effect to this clip.
- Oliver
Orlando, FL
http://www.oliverpeters.com
