Lost projects / events updating from 10.0.5 to 10.0.9
Stefano Neri
on Sep 16, 2013 at 3:10:53 am
Hi!
After upgrading from FCPX 10.0.5 to 10.0.8 I lost all my Compound Clips / Multicam Clips.
I still have the event that was containing the clips,except the compound clips...I'm very afraid,is it possible to recover them?
Best regards
Loren Risker
Re: Lost projects / events updating from 10.0.5 to 10.0.9
on Sep 16, 2013 at 7:34:59 pm
There were some major changes to compound clips in 10.0.6.
When upgrading, it's a good idea to make a copy of all your currentversion.fcpevent and currentversion.fcpproject somewhere FCPX won't see in case you need to restore.
If you didn't do that, hopefully there is a backup. If there is you might be able to downgrade and restore.
OutOfFocus.TV - Original series, music videos, mini-docs.
Jeremy Garchow
on Sep 16, 2013 at 7:51:21 pm
Final Cut should make a backup of the Events and Projects in an "Old Versions" folder in the Event or Project encompassing folder.
The problem is you will need to find a version of FCP 10.0.5 to use them again.
