Why are my Pro Res clips in the timeline still rendering??
kurt dalziel
on Sep 5, 2013 at 1:52:07 pm
I must have some settings wrong. I optimize my media on import, but then when dropping clips into a timeline, the clips still require rendering (orange bar).
Clip properties: 1080p 29.97 Stereo 48kHz Pro Res 422
Project Properties: 1080p 29.97 Stereo 48kHz Pro Res 422
Clips should not need to render, correct? (unless there's filters, transitions,etc)
Ronny Courtens
Re: Why are my Pro Res clips in the timeline still rendering??
on Sep 5, 2013 at 2:17:29 pm
Make sure your imported clips have fully been converted to ProRes (no background processes are active anymore).
Then create a new Project and in the Project Properties window check the "Set Properties based on First Clip" option. Finally add a first clip to the Timeline, making sure this clip is a ProRes clip.
- Ronny
kurt dalziel
on Sep 5, 2013 at 2:24:56 pm
Hey Ronny...where is the "set properties based on first clip" option in the properties window?
Ronny Courtens
on Sep 5, 2013 at 2:36:15 pm
When you create a new Project you first get a window where you can name your Project. In that window, next to Video Properties, you will see "Set based on first video clip". Check that option then press OK.
- Ronny
kurt dalziel
on Sep 5, 2013 at 2:44:12 pm
Ah, thanks, the hidden drop down window.
