Trying to "Share" Interlaced 1920x1080i 29.97 file
Randy Burleson
on Sep 3, 2013 at 8:09:31 pm
My project is 1920x 1080i 29.97 Interlaced. When I go to Share and then use my Compressor H.264 setting it always comes out progressive. I have tried fiddling with the frame control settings and turning frame control off or on and I can't seem to figure out why I can't get an interlaced file out of FCPX/Compressor.
I just want it to be an H.264 file that is 29.97 Interlaced HD 1920x1080i
but it always turns out Progressive! frustrating... What the heck am I doing wrong?
Oliver Peters
Re: Trying to "Share" Interlaced 1920x1080i 29.97 file
on Sep 4, 2013 at 2:09:10 am
I haven't had success with this. I've actually exported uncompressed or ProRes and then used QT7 Pro to create the proper H264 file. It appears to be an issue with how H264 files are handled by Compressor 4 and FCP X. Basically it's messed up.
Oliver
Orlando, FL
http://www.oliverpeters.com
Ronny Courtens
on Sep 4, 2013 at 8:12:35 am
I haven't had time to try this, so this may be a stupid suggestion.
Create a new H.264 setting in Compressor and in Frame Controls set Output Fields to "Top First". Then you save this as a custom preset and it will appear as a new Compressor setting in FCPX. Shouldn't this do the trick?
- Ronny
Randy Burleson
on Sep 15, 2013 at 2:03:11 pm
Ronny, Yeah... you would think, But no.
I already did this and no matter what I do, I can't get an Interlaced 1920x1080i H.264 file
Randy Burleson
on Sep 15, 2013 at 2:07:14 pm
hmmm... I just thought of something... an HD interlaced file should be 59.94 to be interlaced... right?
Is it even possible to get 29.97 interlaced HD H.264 file?
