Copying Effects to multiple clips, and adjusting audio on multiple clips
Jared Boice
on Sep 3, 2013 at 3:39:32 pm
Is there no way to copy/paste effects to multiple clips at once? Or is there also a way to make a universal audio adjustment to multiple selected clips?? thanks
Nikolas Bäurle
Re: Copying Effects to multiple clips, and adjusting audio on multiple clips
on Sep 3, 2013 at 4:43:38 pm
Yes you can cmnd + c to copy the clip, then highlight the clips you want, then shift + ctrl + V
Nikolas Bäurle
on Sep 3, 2013 at 4:48:39 pm
Yes you can cmnd + c to copy the clip, then highlight the clips you want, then shift + cmnd + v to paste. If you need to adjust audio for several clips at once, highlight them, the inspector indicates at the top how many clips its inspecting. You can then adjust volume, or delete effects.
Nikolas Bäurle
on Sep 3, 2013 at 4:51:14 pm
Please ignore my first post, I hit something by accident, wasn't done...:-)
