Share to a specific folder on an external drive (fcpx)
Don Gordoni
on Aug 28, 2013 at 1:24:55 pm
Would someone please tell me how to share to a specific folder, I have been sharing to the i-tunes library on the system drive but would like to share directly to a folder on an external hard drive.
Chuck Pelini
Re: Share to a specific folder on an external drive (fcpx)
on Aug 28, 2013 at 3:28:13 pm
When you hit share, select your settings and then hit next, a finder window should open for you to select your destination.
Bret Williams
on Aug 28, 2013 at 5:34:37 pm
If you do a share to Apple Devices it by default puts it into your iTunes library and there is no next button. If you'd like to save it somewhere else, in the share dialog, under settings, you'll have to choose "When Done: Do Nothing." That will change the share button to a next button. Then pressing next will give you the choice of where you want to save it.
Most of us are probably using compressor presets which can be added to the share menu. I have quite a few as I figure out just what a client likes/wants/works for them. I also have quick decent quality very fast settings for client approvals.
Don Gordoni
on Aug 28, 2013 at 11:36:24 pm
Chuck and Bret:
Thanks for the prompt and helpful replies!
