Wipes on objects in FCPX
Johan Moeskops
on Aug 23, 2013 at 11:15:06 am
Hi.
I wonder, if I put a wipe on an object, so it comes in on a background, the background wipes with the effect.
What's going wrong, it it possible to make it so, that the background is straight and the object comes in with the effect?
Thanks a lot.
Regards, Johan
Don Smith
Re: Wipes on objects in FCPX
on Aug 23, 2013 at 11:41:22 am
I had to read your post twice to understand what you are saying. It appears that you have a background video layer and another clip above it and you want to put a wipe on the clip above to make it appear over the background clip below.
If this is the case it sounds like you're using an effect with a Dropzone layer and that Dropzone layer will affect all video below. Right-click on that effect to Open in Motion, delete the Dropzone and save under another name.
Or, try putting the upper layer in a Compound Clip. Then open the Compound Clip on its own timeline and put the effect on the clip there. Sometimes the Compound Clip will isolate the effect.
Don Smith
NewsVideo.com
Johan Moeskops
on Aug 24, 2013 at 2:16:08 pm
Hi Don.
Oke, I understand, I must make a compound clip of my object.
Thanks a lot, it's a simple solution.
Regards, Johan
