Audio Levels and Compound Clips
scott reynolds
on Aug 11, 2013 at 11:23:08 pm
I've observed some rather odd audio level behaviour with compound clips and was wondering whether anyone has noticed something similar.
My project is a set of compound clips. **Within** each compound clip I have set the audio levels to an appropriate level and verified through the meter for each audio clip.
However when I play the compound clip at the project level, the levels are lower (by almost 6dB) than when I play the same at the clip level.
Even more strange is that if I break apart the compound clip, the audio levels remain at the "lower" values.
I'm sure I am missing something very basic here, so would appreciate any pointers you may have.
© 2018 All Rights Reserved
