Removing Sharpness in Final Cut Pro X
Nicolas Vallejo
on Aug 10, 2013 at 2:24:49 pm
I shoot with a 5D MKIII, and always use a Technicolor Cinestyle profile, which removes contrast, saturation, and sharpness from the image so I can add it in post.
I shot a sequence without all these elements present except for sharpness. Need to take it down quite a bit. Is there a better way of achieving this than gaussian blur?
Fernando
David Battistella
Re: Removing Sharpness in Final Cut Pro X
on Aug 13, 2013 at 9:52:54 am
Try taking it into Resolve, then have some nice softening tools in there that will get the edge off.
IN FCP X use .02 value to soften the image a bit. Work in small fractions instead of with the slider. a .02 pixel blur is often used to soften digital photography.
David
______________________________
http://www.davidbattistella.com
Nicolas Vallejo
on Aug 13, 2013 at 4:48:25 pm
Use a .02 value, where, exactly?
