Izotope
tony west
Izotope
on Aug 2, 2013 at 6:21:50 pm
Is anyone else here having trouble with the Izotope interface not opening in X?
Other audio interfaces open fine. Just this one. I'm on 10.0.8
I e-mailed the company about it and they sent these instructions but still no go.
Just trying to figure out how many people have seen this.
The program will open as a stand alone outside of X and you can work with files like that but not ideal.
To reset Final Cut:
In Finder, hold down the Option key and choose Library from the Go menu.
In the Library folder that opens, open the Application Support folder. Move the Final Cut Pro folder and the Apple Qmaster folder to the Trash.
Return to the Library folder and open the Caches folder. Move the "com.apple.FinalCut" folder to the Trash.
Return to the Library folder and open the Preferences folder. Move the following files to the Trash:
com.apple.FinalCut.LSSharedFileList.plist
com.apple.FinalCut.LSSharedFileList.plist.lockfile
com.apple.FinalCut.plist
com.apple.FinalCut.plist.lockfile
Note: The .lockfile items may not be present on your system
To reset RX 2:
In the Library folder that opens, go to Preferences. Delete any file with com.izotope.audioapps in the title
Go to the ByHost folder. Delete any file with com.izotope.audioapps in the title
Download and run this installer: http://downloads.izotope.com/product_download/iZotope_RX_v2_10.dmg
Jeff Kirkland
Re: Izotope
on Aug 2, 2013 at 10:24:00 pm
Not much help but no, izotope RX2 is working fine for me in FCPX.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
tony west
Re: Izotope
on Aug 2, 2013 at 10:27:39 pm
Thanks Jeff, it actually does help to know if it's just me or not.
They said they didn't have any reports from other users with the same problem.
Colin Ryan
Re: Izotope
on Aug 2, 2013 at 10:30:23 pm
i have always used RX as a standalone. Nectar and Ozone always worked fine within FCPx for me. I did have nectar crash a few times in fcpx because i applied it to alot of small clips, but applied it to those same clips as a compound clip it never stuttered.
let your fingers do the walking
tony west
Re: Izotope
on Aug 2, 2013 at 11:13:51 pm
Thanks Colin
Brett Sherman
Re: Izotope
on Aug 4, 2013 at 1:33:04 pm
I always use it outside FCP X. I found it extremely difficult to get a noise sample from within FCP X. And Spectral Repair is impossible. My procedure. Disable (V) other tracks to get the sound isolated in FCP X. Set in and out in timeline. Export to AIFF. Right-click file and open with Izotope RX. Make adjustments. Save as .WAV file. Drag straight into timeline. Disable original audio track. Enable (V) other tracks.
tony west
Re: Izotope
on Aug 7, 2013 at 2:34:30 pm
Thanks Brett, I will most likely do the same.
