Best Workflow to Create a PAL DVD from FCP X
Jeff Krieger
on Jul 27, 2013 at 2:21:23 am
I need to go from HD in FCP X to a PAL DVD. I have Compressor if needed. What is the best workflow. Someone please help. I can't find anything, and I've been looking a while. Thx.
Jeff Kirkland
Re: Best Workflow to Create a PAL DVD from FCP X
on Jul 27, 2013 at 8:42:41 am
The simplest is to duplicate the project, change it's properties to be a PAL SD DVD compatible format, then share as a DVD.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Ronny Courtens
on Jul 29, 2013 at 10:13:39 am
I'm afraid when you duplicate an edited NTSC Project you won't be able to change the Project Settings of the duplicate to PAL as you cannot modify the time base of a Project once it has media inside.
But you can create a new Project using PAL settings, then copy/paste the content of the NTSC Project onto the PAL Project.
I must say I have pleasantly been surprised with the way FCPX conforms NTSC video to PAL on the timeline. The Rate Conform tool works extremely well, even using the basic Floor settings.
Jeff Kirkland
on Jul 29, 2013 at 10:38:39 am
What he said :-)
