Adding a pulsing red dot to a map
Dan Wiseman
on Jun 28, 2013 at 12:14:03 pm
Hi all. I want to add a pulsing red dot to a map to guide people to certain locations along a river. Is there a way to do this in FCPX please? Thank you
Jeremy Garchow
Re: Adding a pulsing red dot to a map
on Jun 28, 2013 at 3:22:53 pm
Maybe this: http://www.rippletraining.com/categories/plugins-and-templates/jumps/jumps-...
Dan Wiseman
on Jun 30, 2013 at 1:07:22 pm
Ok thank you all for your feedback.. I will have a go :)
Michael Sanders
on Jun 28, 2013 at 8:43:33 pm
Motion? Pulse the opacity and then loop it.
Michael Sanders
London Based DP/Editor
Jeff Kirkland
on Jun 28, 2013 at 9:47:55 pm
If its just a single dot you could even just key frame opacity and position in FCPX. It'd only take a couple of minutes to create a repeating pulsing dot compound clip and then you could move that around the map.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Bret Williams
on Jun 29, 2013 at 4:26:36 am
I don't think I'd Keyframe it. I'd make one dot that fades in and out with a dissolve. Copy it. Ten paste it a zillion times. All in a compound as mentioned.
