Final Cut Pro X - Retiming
Adam Rahmani
on Jun 26, 2013 at 10:41:43 pm
Hello all,
I am starting to try and get familiar with Final Cut Pro X, I did a little personal project with it which involved some retiming of a few clips, now a few days later I went back to the project and I cant remember which clip is retimed and which isnt, I could watch it through again but I don't even remember what speed percentage I used is there a way to preserve the little bar above the clip that is added when you first tell it to retime? or another way of doing this?
Adam
Jeremy Garchow
Re: Final Cut Pro X - Retiming
on Jun 26, 2013 at 10:52:45 pm
Command-r will bring up the retiming editor. You have to select all and hit command-r.
Anything that is not green is retimed.
Adam Rahmani
on Jun 27, 2013 at 3:16:15 am
thanks this sort of worked, selecting all and hitting command r didnt bring up anything but when i went individually it worked
Jeremy Garchow
on Jun 27, 2013 at 3:39:38 am
Weird. It works here.
Adam Rahmani
on Jun 27, 2013 at 4:55:28 pm
Maybe i'll try installing either way it still kind of worked. Thanks for your help.
