Exporting small sequences from a large sequence.
dan crouch
on Jun 25, 2013 at 8:13:32 pm
Hi Guys,
I am trying to export several 2 minute selected scenes from a long documentary.
I have tried copying the clip, cmd a, then opening up a new project and pasting, but the aspect ratio hasn't transferred.
The image is small and when I transform to full screen, it looks like it's blown up.
I have also tried to copy whole project then delete the stuff I don't want, leaving the clip I want to export but this takes ages to copy.
Is there a quicker way?
Any help would be fantastic,
Thank you.
Dan.
Jeff Kirkland
Re: Exporting small sequences from a large sequence.
on Jun 25, 2013 at 8:30:54 pm
Just exporting a selected range isn't working fro you?
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
dan crouch
on Jun 25, 2013 at 9:15:43 pm
Thanks for the post Jeff,
I was under the impression the only way to export was to do it from the project window. Is there a way to do from the timeline?
Cheers,
Dan.
Jeff Kirkland
on Jun 25, 2013 at 9:45:24 pm
Unless we're talking at cross purposes, you just open the timeline, select a range and choose your appropriate share option - Final Cut will export just the selected range.
dan crouch
on Jun 25, 2013 at 10:57:20 pm
Thanks for that Jeff,
I can see now that it can be done!
Thanks very much for that. Is it a recent update? I couldn't find anything online that shows you how to do that, just lots of annoyed editors saying you can't.
Thanks again,
Dan.
Jeff Kirkland
on Jun 25, 2013 at 11:05:39 pm
Added in 10.0.6 I think... glad it's working for you.
cheers
Jeff K
Bret Williams
on Jun 26, 2013 at 12:49:03 am
And before that you didn't have to export from the project library. But you couldnt' do a range select.
