transitions and layers
Julian Bowman
on Jun 19, 2013 at 3:57:10 pm
Why does, and/or how do I stop:
if i have say a series of text generators on my timeline and I group them together as a compound clip and I want to use a transition filter to get them off the screen, why when i put the transition on the compound clip does the transition filter affect the clip beneath my compound which in this case is my image over which the text sits.
It isn't just this scenario, have more than one layer of stuff and you add a transition to the top layer then the transition affects the bottom too, for example it will run the transition on the top layer then at the end blur or move or whatever the clip below.
Right pain in the rear, making a lot of transition use as effects impossible. Now this was something you could do in 7, so am I missing something or is this just another bug?
Cheers
