X-Files Pro Public Beta
Andreas Kiel
on Jun 12, 2013 at 5:08:49 pm
I decided to publish the current Beta for all.
Usage is limited till August 1st.
A rough manual and the application download can be found at:
http://www.spherico.de/filmtools/X-Files/
Feedback welcome.
-Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
James Cude
Re: X-Files Pro Public Beta
on Jun 12, 2013 at 5:57:49 pm
Looks like a great util. I would recommend a slight name change to avoid any trouble from the folks over at Fox though...https://en.wikipedia.org/wiki/The_X-Files
Andreas Kiel
on Jun 12, 2013 at 8:06:47 pm
there shouldn't be any conflict using that name. i've read some legal stuff.
the app has nothing in common with scifi (i hope -- ask apple about x files), i'm not selling mugs or t-shirts etc.
in case there would be problems, i will change the name to fcp x-files.
-andreas
Spherico
Bill Rabkin
on Jun 13, 2013 at 9:31:02 pm
I downloaded, installed, and launched the X-Files Pro Public Beta. It displayed my external FW800 drives in its "Final Cut Pro X Volumes" window, which shows 8 drives (7 of which are "True" for FCP X; the other drive is my Time Machine backup drive).
However, all menu choices in the "Events & Projects" menu pull-down are disabled (greyed out). This is still true if I select a drive in the "Volumes" window.
How do I manage Events and Projects?
Suggestion: Don't use Command+P for the "Manage Events & Projects" command. That shortcut is widely used for "File > Print."
FastBill
Andreas Kiel
on Jun 13, 2013 at 10:20:54 pm
Bill,
sorry, seems I have swapped versions on the server. i will fix that tomorrow morning (european time).
thanks for the feedback.
-andreas
Spherico
Andreas Kiel
on Jun 14, 2013 at 7:20:13 am
Hi all,
The correct version is back on the server.
-Andreas
Spherico
