Alpha Channel Setting Keeps Changing Back
Nick Sbordone
on Jun 9, 2013 at 6:32:08 pm
Hey all,
Just diving into FCPX and I had a question about hte alpha channel. After finding the setting in the inspector, I switched it to premultiply. However, it does not update in the timeline and upon clicking out of it, the inspector reverts the setting back to "ignore alpha." It does this whether I change the clip in the Project or the Library. The title animation was exported from After Effects with the Animation preset.
I assume it's something simple, however I'm going mad trying to figure this out.
Any thoughts?
Jeremy Garchow
Re: Alpha Channel Setting Keeps Changing Back
on Jun 12, 2013 at 3:07:40 am
Changing a clip in the Project will not change the data back in the Event.
Changing the clip in the Event will not ripple the change to existing Project instances.
You should change it in the Event, and every time you add a new instance to a Project from that point forward, it should stick.
Is that not what you're seeing?
