Export FCPX file with roles including master audio mix
Henrik Helms
on Jun 7, 2013 at 11:39:08 am
Hi!
Is it possible to export a project as roles also to include a master mix in the first two audio tracks of the multitrack file?
Greetings
Henrik Helms
dBA MEDIA
Matt Trubac
Re: Export FCPX file with roles including master audio mix
on Jun 7, 2013 at 11:50:21 am
Would it work to duplicate (copy and paste your audio clips?) and put the duplicates in a compound clip, and assign a role?
Someone else might have a more elegant solution.
Jeremy Garchow
on Jun 7, 2013 at 2:28:08 pm
Yes.
You can add a channel, then select all the roles for that channel.
