Inverting footage...
Ignacio Holiday
on May 13, 2013 at 10:47:14 pm
What I want to do is take some footage, invert it, and have it running alongside the same clip so it looks like a character is talking to himself. This is pretty easy to do by cropping and re-sizing, the only problem is that there is a visible line between the parallel footage as both of them play at the same time. Is there a way of getting rid of this line? Maybe there's a plugin that would make this easier to do...
Nikolas Bäurle
Re: Inverting footage...
on May 14, 2013 at 9:15:45 am
Blur the edges.
With a perfect kamera lighting setup you shouldn't see much of a line, but a lot of times its not possible, especially when shooting outoors. The easiest way would be to blur the edges, or if its not very much, simply reposition one of the shots to match the other.
"Always look on the bright side of life" - Monty Python
Nikolas Bäurle
on May 14, 2013 at 9:20:30 am
To correct my last advice: its for the situations when you have two different clips. In your case you need to simply blur the edges.
Ignacio Holiday
on May 14, 2013 at 6:27:03 pm
How do I blur just the edges?
Nikolas Bäurle
on May 14, 2013 at 9:25:28 pm
You need the Crop & Feather filer, in the effects browser, under distortion
