Is it possible to do a keyframe motion so that the clip moves at the same speed.
Dimitrios Papagiannis
on May 6, 2013 at 4:39:20 am
In other words I want a clip to move from 0 to -100 in the x direction. However I don't want it to ramp up to 100 or down to 0 at the end. I just want it to move at the same speed across the entire move from right to left without speeding up or slowing down (in other words get rid of "easy out" and "easy in").
Bret Williams
Re: Is it possible to do a keyframe motion so that the clip moves at the same speed.
on May 6, 2013 at 1:12:16 pm
There are some bizarre workarounds and I'm sure someone will chime in.
But if its that simple, you can animate the crop effect. It's completely linear.
Mark Morache
on May 7, 2013 at 9:54:05 am
Again...
This should help you until they get it fixed.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
