Viewer Clips to compessor
Mark Smith
on May 6, 2013 at 12:59:33 am
With the latest version of FCPx its possible to select a clip in the viewer and send it to compressor, but is it possible to select more than 1 clip and send those clips to compressor?
Kyle Bass
Re: Viewer Clips to compessor
on May 6, 2013 at 2:37:40 am
You can't send several clips separately to Compressor, but you can send a range to Compressor. Just use the Range tool (R key) or use the I and O keys in the timeline to specify a range. Then use the Send to Compressor command.
Mark Smith
on May 6, 2013 at 11:15:55 am
I understand the range slect and export. What I want to do is select a number of clips in the viewer and send those to Compressor, but so far FCP only allows one clip at a time to be selected and sent to compressor. I ' like to be able to select a group of clips in the viewer and send them as a batch to compressor.
Bret Williams
on May 6, 2013 at 1:16:59 pm
Do you mean the event? The viewer is where playback is displayed. Called the canvas in 7. You can also open up a dedicated event viewer.
But no, you can't batch anything from anywhere.
Mark Smith
on May 6, 2013 at 4:13:12 pm
Doh ! I meant event browser. I can send one clip at a time from the event browser to Compressor, but I would like to send multiple clips. Seems like I am boxed out of that option.
Bret Williams
on May 6, 2013 at 10:26:48 pm
Batch export is a big request - at least from the project library. I suppose you could request it from the event browser as well.
