Stereo vs Dual Mono preference
Bruce Wittman
on May 1, 2013 at 3:38:39 pm
Hey Cowboys and Cowgirls,
Don't know if there is a preference setting for this. All my work involves dual mono audio recording. Channel one may be a lavalier mic and Channel two may be a shotgun mic. Every time I add a clip on the timeline, I have to go to the audio panel and change the setting from stereo to dual mono, so I can select the one channel I want to use.
Any way to make the default audio setting be "dual mono" instead of "stereo"?
Thanks in advance for all the help!
Bruce Wittman
Executive Producer
Eagle Video Productions, Inc.
2201 Woodnell Drive
Raleigh, NC 27603-5240
Website: http://www.eaglevideo.com
Email: bruce@eaglevideo.com
pho: 919-779-7891
cel: 919-818-5556
Jeremy Garchow
Re: Stereo vs Dual Mono preference
on May 1, 2013 at 5:41:11 pm
Select all of your video clips in the Event.
Change the audio from Stereo to Dual mono in the inspector.
Every time you add a clip to the timeline, it will now be dual mono.
Jeremy
Bret Williams
on May 1, 2013 at 6:20:07 pm
Can also have it auto-detect on import, but I've had mixed results.
Jeremy Garchow
on May 1, 2013 at 6:31:13 pm
[Bret Williams] "Can also have it auto-detect on import, but I've had mixed results."
Ditto
It's not reliable.
Bruce Wittman
on May 1, 2013 at 6:35:18 pm
Hey Jeremy,
Thanks! You just saved me hours of work.
This is why I love Creative Cow.
Within minutes, I have learned something new and important from someone way smarter than me.
Bruce Wittman
Executive Producer
2201 Woodnell Drive
pho: 919-779-7891
cel: 919-818-5556
Jeremy Garchow
on May 1, 2013 at 6:41:56 pm
[Bruce Wittman] "from someone way smarter than me."
Surely, you jest.
i just have you fooled!
Brett Sherman
on May 4, 2013 at 1:24:32 pm
[Bruce Wittman] "Any way to make the default audio setting be "dual mono" instead of "stereo"?"
I do the workaround all the time. But there really should be a preference item for it so you don't have to waste time changing them. If you have an event with a lot of clips it actually takes awhile.
The preference should allow different settings for clips from camera, imported clips, and clips from iTunes.
Noam Osband
on Apr 28, 2015 at 7:40:21 pm
This was a good article to find!
I've been doing lots of work with one track of audio. I always deselect the second mono track which is always empty. Do I need to do that? Would there be a change if I didn't?
Doug Metz
on Apr 29, 2015 at 10:05:45 pm
Mono tracks are panned center, so if you've got a silent track it shouldn't have any effect.
Doug Metz
Anode
