How can you see 4 audio tracks in timeline?
Ned Miller
on Apr 30, 2013 at 11:02:49 pm
I did a two camera shoot, each camera used all four of their audio channels, yet when I import I on;y see one track, which I think X has mixed? I need to have control over each individual track to fade up or down depending on which podium mic was used. Can someone please tell me how I can display and manage audio tracks?
Thank you
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.com
Andy Neil
Re: How can you see 4 audio tracks in timeline?
on Apr 30, 2013 at 11:24:36 pm
Presuming you have the most recent version, or at least 10.0.7, you can OPT+double click the audio portion of the clip to reveal the discrete channels and keyframe or disable them as needed.
Andy
http://www.timesavertutorials.com
Julian Bowman
on May 1, 2013 at 5:22:07 am
I may get this a bit wrong, but I need to do something similar when I record two channels on a stereo file and FC gives me a single track file.
It can be done and is easy when you know how.
Highlight the file and go to the inspector, somewhere in there ( near the bottom I think) is an option to show individual mono tracks rather than a stereo track. Choose that and you gain access to the individual channels.
This side of things isn't very elegant in FCX but it works. I have a tendency to break the channels apart and separate them from my video clip just so I can view my audio as separate tracks because I prefer seeing everything in my timeline rather than having it all tucked away into a single does all file. I am a bit of a nay sayer about all this enforced de-cluttering that X does but once you get your head around it the workarounds are easy and become second nature even if a it annoying that they need to be done and you need to 'unpack' your timeline just to work it as ,you may wish.
Bret Williams
on May 1, 2013 at 7:22:17 pm
Breaking apart is likely a bad idea for something as simple as this. Read Andy's post above. FCP addressed this in 10.0.7.
