Google Earth KMZ files into FCP
Craig Ryder
on Apr 30, 2013 at 9:48:57 am
I'd like to import Google Earth KMZ movie files into FCPX. Is there a (best) way/conversion to do this?
Thank You
Craig
Matt Larson
Re: Google Earth KMZ files into FCP
on May 1, 2013 at 9:15:59 pm
It's been a while since I've used Google Earth, but isn't there a way to export Quicktime movies from the application? Save them out as ProRes files and they should import into FCPX just like anything else
Mark Freeman
on Jan 11, 2016 at 7:49:41 pm
I was searching for a solution to this problem
Old solution:
  • Found that Quicktime screen capture was being recommend in the past.
  • Newest solution:
  • Since Google Earth Pro is now free, you able about to create Movie from a "Tour" (Add / Tour).
  • Steps:
    • Make you tour: Go to Add / Tour and create your Google Map tour
    • Make your movie: Go to Tools / Movie Maker. Lots of formats to choose from in thet setup.
    • Import to FCPX
    Keywords: movie google maps earth pro import final cut fcpx tour movie maker
    Mark Freeman
    Vancouver, BC, Canada
