very best way to compress for youtube
ed sayers
on Apr 29, 2013 at 4:01:37 pm
hi all
can anyone recommend the very best way to compress for youtube?
most up-to-date info only please...
this is YT latest spec guide: http://support.google.com/youtube/bin/answer.py?hl=en-GB&answer=1722171
my project is 1920x1080 (p) PAL 25fps
we've been using mpeg streamclip and will try compressor 4.07 next
will be using 50k bt rate (50,000)
just checking we're not throwing away any quality we don't need to
thanks
e.s.
Bret Williams
Re: very best way to compress for youtube
on Apr 29, 2013 at 4:50:58 pm
No luck with the built in YouTube encoder/uploader?
ed sayers
on Apr 29, 2013 at 4:54:06 pm
thanks brett
just realised i posted in the FCPX forum
this project is in FCP7 and looking to compress having exported pro res
thoughts welcome...
ed
Bret Williams
on Apr 29, 2013 at 5:08:14 pm
When I open up the older compressor it also has a YouTube sharing function. Not sure how up to date those settings are though.
ed sayers
on Apr 29, 2013 at 5:10:10 pm
thanks again
do you have any opinion of mpeg streamclip?
ed
Tony Brittan
on Apr 29, 2013 at 4:56:18 pm
And if the actual sharing doesn't work, you'll find the converted file in the shared folder inside the project using finder. Then upload directly via a browser. Makes perfect files in my experience.
Tony Brittan
Island Shore Productions
Kill Devil Hills, NC
Loren Risker
on Apr 29, 2013 at 6:14:54 pm
Your settings look good and mpeg streamclip can get the job done.
One thing neither MPEG streamclip nor FCPX's share to youtube doesn't do is give you the option for fast start and compressed header. Compressor does.
Moov atom at the front of the file (Fast Start)
OutOfFocus.TV - Original series, music videos, and entertainment for your couch.
Bill Davis
on Apr 29, 2013 at 6:08:56 pm
Go to the Share menu.
Select YouTube.
If you've set up your YouTube account ID info and password properly - you click Share and a perfectly encoded version appears in your YouTube account.
Pretty much as simple as that.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Claude Lyneis
on Apr 30, 2013 at 4:30:59 am
I usually use compressor but I tried the share to Youtube approach. The video came out with these settings.
HD 720p.mov
H.264, 1,280 x 720 (1,248 x 720)
Audoe AAC, 48000 Hz, Stereo (L R
Data Rate 10.34 Mbit/s
29.97 FPS
Note, the raw video was 1080i AVCHD. Of course the quicktime inspector does not show all the setting such as fast start for the internet.
Bill Davis
on Apr 30, 2013 at 6:09:03 am
720p scales beautifully to all sorts of modern mobile platforms. It creates lovely iPad & iPhone retina display images and great looking android and even older style cel phone deployments.
So it's become my default. I shoot and produce in 1080 - but I typically output everything to 720p 24 frame for delivery because it both compresses and scales so well across my most important distribution platform, and that's the internet.
FWIW.
Julian Bowman
on Apr 30, 2013 at 6:55:59 am
FCP7 doesn't have a share menu.
ed sayers
on Apr 30, 2013 at 3:32:43 pm
hi all
thanks for all your comments
so it looks like we will gor for this:
exporting from fcp7 at original settings (prores etc)
use latest version of compressor (4.0.7) to make
an mp4 file that's h264
with youtube's highest acceptable bit rate (50000kb!)
at full 1920x1080. (which is client specification, though point-taken about 720, thanks).
with AAC stereo audio at appropriate bit rate as per YT guidelines.(linked above in my first post)
now it's just a question of whether to use either of these compressor streaming options:
fast start
or
fast start - compressed header
larry jordan's clip doesn't say to do this.
doesn't YT make this happen anyway? when they re-compress (AS THEY DO!) ?
OR...
is it better to do it in compressor ourselves so YT has less work to do?
- anyone work at google/YT??
we aim to test both on private YT links but upload times are long!
thanks
e
Ricky Dominguez
on Apr 30, 2013 at 2:46:32 pm
I use Larry Jordan tutorial and it works:
Compressing for YouTube - Final Cut tutorials
Ricky Dominguez
Luna Films
Puerto Rico
