FCP won't recognize Motion?
Ignacio Holiday
on Apr 29, 2013 at 4:18:09 am
When I try to right click on a title in FCP and modify it in Motion it keeps telling me that I must have Motion 5 installed, but it is installed. I tried re-installing it and nothing changed. Why won't it recognize motion?
Jeremy Garchow
Re: FCP won't recognize Motion?
on Apr 29, 2013 at 6:20:23 am
Do you also have fcs3 installed?
Oliver Peters
on Apr 29, 2013 at 11:59:56 am
If you have FCS3 also installed, trash all prefs for both sets of apps. Launch the old Motion first to re-establish paths to the old FCP7. Then launch FCP7. If these two open fine, then you should be OK again with FCP X and Motion 5.
Oliver
Orlando, FL
http://www.oliverpeters.com
Ignacio Holiday
on Apr 29, 2013 at 4:12:45 pm
I don't know what FCS3 is, so I don't think I have it...
Jeremy Garchow
on Apr 29, 2013 at 4:13:05 pm
Final Cut Studio 3
Ignacio Holiday
on Apr 29, 2013 at 4:18:16 pm
Nope, I don't have that.
Jeremy Garchow
on Apr 29, 2013 at 4:21:14 pm
Is Motion installed in the Applications folder or have you moved the application to another folder?
Jeremy
Bret Williams
on Apr 29, 2013 at 4:54:13 pm
Classic! Has anyone noticed all the FCP X posts over at the FCP forum? They need to rename it FCP versions 1-7 forum or something.
Ignacio Holiday
on Apr 29, 2013 at 5:31:14 pm
Yes, it's installed in the applications folder..
Jeremy Garchow
on Apr 29, 2013 at 5:33:08 pm
Try trashing prefs for both FCPX and Motion 5. Have you launched Motion 5 yet?
Ignacio Holiday
on Apr 29, 2013 at 5:48:30 pm
I did launch it, but I'm not sure how to trash the prefs...
Jeremy Garchow
on Apr 29, 2013 at 6:15:48 pm
The free Preference Manager from Digital Rebellion should help you.
Jeremy
Ignacio Holiday
on Apr 29, 2013 at 8:40:53 pm
Thanks for the tip. I installed the program and trashed the preferences but I'm still getting the same message. I re-installed Motion too and it didn't seem to help.
Jeremy Garchow
on Apr 29, 2013 at 9:30:49 pm
Just to see if this works, let's try going the other way, can you create a Motion template in Motion (use a "Final Cut Effect" or "Final Cut Generator") and have it show up in FCPX?
Jeremy
Ignacio Holiday
on Apr 29, 2013 at 9:56:09 pm
Yeah, FCP will recognize items made in Motion but not the other way way around apparently. They need a therapist to learn to communicate better.
Jeremy Garchow
on Apr 29, 2013 at 11:10:25 pm
[Ignacio Holiday] "They need a therapist to learn to communicate better."
Certainly some creative counseling otherwise known as criticism.
If you make a new admin user does it work?
Ignacio Holiday
on Apr 30, 2013 at 6:48:55 pm
I'm not sure what you mean; if I sign in as guest I can't run FCP.
Jeremy Garchow
on Apr 30, 2013 at 6:53:58 pm
You have to create a whole new account.
Open Sys Prefs, Choose Users and Groups, create a new user with admin privileges.
Jeremy
Ignacio Holiday
on May 1, 2013 at 2:57:42 am
Okay, well I tried this too and still no luck...
Ignacio Holiday
on May 1, 2013 at 3:27:37 am
I'm just trying to modify a FCP title in Motion. It doesn't matter which title or transition I click on, I get the same error message every time.
Jeremy Garchow
on May 1, 2013 at 3:29:14 am
Not all titles and transitions are editable.
Jeremy Garchow
on May 1, 2013 at 3:04:48 am
Again, what Title are you trying to open?
