pre-keyed footage problem in final cut pro x
Sera Horse
on Apr 28, 2013 at 10:19:46 pm
Hello, first time posting. I was working with pre-keyed footage in fcpx, it's a 3D project, I don't know if that makes any difference. Anyways I got everything placed and corrected and everything squared away and thought to try to combine this project with another larger project, so I turned the clips I was working with into a compound clip so I could open them in this other project. When I did so all the pre-keyed footage became un-keyed, there were big black boxes everywhere. And when I broke up the compound clip they remained that way, completely unkeyed. Thanks for any help.
Jeremy Garchow
Re: pre-keyed footage problem in final cut pro x
on Apr 29, 2013 at 6:22:06 am
Be sure to check the alpha type in the inspector.
You might have to set the metadata view to extended or make your own.
