Does proxy/original preference affect sharing/send to compressor?
David Powell
on Apr 24, 2013 at 6:37:12 am
The title says it all. Do I have to switch back to Original before sending to compressor?
Nikolas Bäurle
Re: Does proxy/original preference affect sharing/send to compressor?
on Apr 24, 2013 at 11:25:45 am
Yes. If you stay in Proxy it will render a Proxy.
"Always look on the bright side of life" - Monty Python
Mathieu Ghekiere
on Apr 24, 2013 at 12:51:23 pm
If you are in Proxy Mode, and share from FCPX straight, it will render out as Proxy.
Not sure if this is also the case when sending to Compressor... I would guess not, but I could be wrong.
Jason Brown
on Apr 24, 2013 at 4:54:23 pm
I like how easy it is to switch between proxy and how it is global, but I'd really like some kind of dialogue telling you when you share a "master file" that you are doing so in proxy mode. I've sent out final master flattened prores many times at proxy without intending to. There should be a dialogue that you can turn off if you want to.
