Freeze frame on a generator
Tom Fox
on Apr 23, 2013 at 2:55:01 pm
Is there anyway I can create a freeze frame on a generator I created in motion?
Jeremy Garchow
Re: Freeze frame on a generator
on Apr 23, 2013 at 3:07:03 pm
Put it in a compound clip.
Tom Fox
on Apr 23, 2013 at 3:11:37 pm
Duh. Just worked it out...
Although I am having an issue whereby I am transforming the compound clip and the generated clip within it does not seem to be moving.
Jeremy Garchow
on Apr 23, 2013 at 5:17:36 pm
[Tom Fox] "Although I am having an issue whereby I am transforming the compound clip and the generated clip within it does not seem to be moving."
Meaning you are trying to change the position of the clip, but the generator stays put?
Tom Fox
on Apr 23, 2013 at 5:20:54 pm
Correct. Not sure if it is intermittent...
Jeremy Garchow
on Apr 23, 2013 at 6:25:45 pm
What generator?
